How to tell if I have 4-wheel ABS
'99 F150 4WD.
I realize the ABS sensor is buried inside the hub, but I don't see any wires or connections other than a brake line coming off the front wheels.
Here's a top-down view of the wheel (tire is a bottom of frame)
Would you say this truck is RABS only?
Thanks for any help.
>>Also you linkage for your swaybar is broken.<<
Sure is! Thanks. I'm on it.
My ((ABS)) and BRAKE (!) lights are on. I replaced the sensor in the differential.
Brake fluid is ok. Brakes work fine. Disconnected the battery for about four minutes but lights came back on. Fuses are good.
I'm guessing the front wheels aren't part of the equation. Not sure where to look next with RABS system.
Any thoughts?
Any thoughts?
Any thoughts?
