Tire Wear
Tire Wear
can someone, anyone tell me what went wrong here?
these tires barely lasted 12 months (minimal driving, not daily driver), and at close to $300 a pop, i need to get it right when i replace them. this is ridiculous. what is the best way to align tires this size these are Mickey Thompsons MTZ. the rear tires are like brand new.
Driver Side Front
Passenger Side Front
12 months ago
Looks like to me your wheels where negative cambered and caused the wear on the insides.
Tirerack description about camber
I agree. Your front end alignment is the issue. The tone of your post sounds like you think the shop didn't align it correctly. But keep in mind, the alignment could have been "knocked out" quickly. For instance, offroading, hitting a curb, hitting a pothole or any number of things could have ruined the alignment. That is why it is important to keep a close eye on your tire wear. I know you probably don't want to hear this, but you should have noticed the uneven wear long before the tires reached that point.
kingfish hit the nail on the head, looks like you've got a front end issue. If the alignment was done by someone that does it daily, it wouldnt of been wrong. So, I say thats not the issue. Jack up the front end and check for play top to bottom and side to side then check the boots and bushings in the front end. Had same wear from tie rod ends, and idler and pitman arm
