05 Wheels on a 2010 XLT Screw
05 Wheels on a 2010 XLT Screw?
Will these fit without any issues? I currently have the 20's but would like to go to a 18 inch wheel. I have found a set of 05 Aluminum Alloys off of a FX4 but would like to know in regards to the larger brakes if they will fit?
Any help is appreciated.
A couple of threads.
https://www.f150online.com/forums/20...ms-2009-a.html
https://www.f150online.com/forums/20...-2009-fx4.html
So from what I'm reading, the 18" 2005 FX4 Rim will need a 1/4" spacer on the front in order to clear the calipers?
I'd rather not go with a spacer but I want to go with a better tire for winter than the stock pirellis that came with it.
I may just go with a 2" AS kit and the 275/65/20 Terras?
The problem isn't the diameter of the brakes, it is the width of the calipers. In some cases the OE wheels for for earlier model F150s (04-08) hit the sides of the calipers. The wheels fit over the caliper fine.
