295/70/18 and XD Monsters
Thanks to everyone who provided their insight in this thread. It made my decision very easy.
We got the leveling kit installed fairly quickly and without any difficulty this afternoon. After mounting the tires I took it for a test drive. I backed up to turn around and I heard the dreaded "click click click click". Rubbing after 6 feet...
The tires were making contact on the black plastic piece on bottom side of bumper (valence?) and the rear portion of the front fender. They were both easy fixes - we just trimmed a little off the valence (maybe 1/4in) and we removed a screw that was pushing the fender "flare" out about a 1/2in and reinstalled the screw through the fender "flare." I'm sure that makes no sense but I can take pictures if needed. After that, no rubbing.
Overall, I'm very pleased with the leveling kit and the tires. The tires definitely take away any pep that my truck had. (Programmer is next.) However, I'll take a slight hit in the performance department for the new look.
Hope you guys like...
Before:
After:
Edit: Sorry for the crappy picture quality. I took it with my phone. Hopefully later this week I can get some better pics.
Before:
After:
Hahaha. I was just about to reply to your post when I saw you had edited it. I saw that you asked about the handling (or something like that). To be honest, the tires feel a little "mushy" when you're at highway speed. Of course, I just had the factory Pirelli's on there. I know the lugs on the tread are causing it. It doesn't bother me, but its something to get used to.
With all of that said, I absolutely love my new setup. It looks and feels like a completely different truck.
great truck btw! i have the same truck but black and i plan on going with almost the exact same setup accept ill be using terra grapplers with 2.5" on the front with 1" in the rear.
My situation was a serious pain in the rump.
When I took it to the dealer, they couldn't get the sensors trained. They told me Rimz One had used the pull through sensors instead of the bands. After a phone call to Rimz One, I set up an appointment with them to change out the sensors. I drove an hour and half back to the shop, and the guys at Rimz One started changing out the sensors. I waited for about an hour and went outside to check on the status. I was told they were waiting on two more sensors from the Ford dealership. I have an appointment to have the sensors replaced but they don't have all the sensors.... I let it slide and went back inside. The sensors got there a few minutes later and they put them on.
They took my truck for a drive so that it would "re-calibrate itself." No luck. They come back and mess with the pressure in the tires and leave again on a "re-calibration drive." No luck. At this point the owner comes out and tells me they can't get the sensors retrained. I asked them if they did the manual retraining with the wand. They said they couldn't find the procedure so I had to look it up on here from my phone. They try the procedure and no luck. The owner comes back out and offers to take my truck to the local dealer to get "diagnostics run". I said OK and off they go. 15 minutes later they are back and the sensors are trained.
After waiting 4 and 1/2 hours at the shop the owner profusely apologizes and offers $150 credit to my account. Overall, it took 7 1/2 hours that day to get home with functioning sensors. It sucked, but the guys at Rimz One did everything they could to help me out.
did you have to purchase anything to get the sensors to work or does it just require a recalibration(training)?
Thanks for the compliment!
Be sure to post pictures when you get the lift and tires installed.
I've tried several times to upload my trimming pictures and I keep getting an error. I'll try again when I get home from huntin' tonight.
