Need Help (Wheels & Tires version)
Alright I am about to go all in and get rims, tires, and a 2 1/2" level kit. I drive 95% of the time on paved roads so looking at BFGs AT since I've had them in the past. But I would listen to arguments for a M/T style especially Nitto's Trail Grappler. Are M/Ts worth it for me? Functionality and wear lifte are more important than looks. I am thinking a 275/70/18 but will this look puny with the level?
Next, really need help on rims. I would love to get some XDs (18x9) but I have been in RimzOne and can't seem to find them in our 5x135 bolt pattern. I've looked at Monsters and the Hoss. Am I overlooking something because I know a ton of people on here have XDs (none where I live though)?
Lastly, I know this isn't the suspension section but does anybody have a recommendation for the level kit? I know they can be had on Ebay for $70 but are they good quality?
Thanks for all the input anybody can give me.
I've got a 1.5" level kit from ebay (AutoSpring) Quality seems fine, and I have 275/70/18's BFG's on my truck, have a look. I think they are the perfect sized tire for these F150's, they are a little heavier than stock though and you will notice that. Our bolt pattern is not 5 X 135 that might be why you are having trouble..they are 6X135. XD's are nice, I've really like the addicts but my factory rims are fine for me. Since you are on the highway 95% of the time, BFG ATs are about as aggressive as I would go for you, no need for a MT.
If your driving on the highway most of the time then the AT's will be the way to go. MT's will be much louder and wear faster. Not much benefit to you except that they look good. As far as the leveling kits go, there are many out there. On thing I found out on my 2004 FX4 was that with 70,000 miles on the truck it was way over due for shocks. I wanted to put the Bilsteins on it but Bilstein does not recommend using the the standard HD shock with a leveling kit. I already has the leveling kit on my truck when I bought it, so I ended up taking the kit out and installing the Bilsteins HD 5100 that have the lift built in to the front shocks. Best move I could have made. The truck rides great and I got a 3" lift on the front and already had the 1" block in the rear. Just a thought.
http://www.tirerack.com/a.jsp?a=BZ1&...ries+Adj+Shock
Well if you are set on the 9" wide rims you can go with 285/65/18 but you are going to pay a little more each tire and loose a little in diameter (maybe like .5 of an inch). Pretty sure they can switch your TPMS sensors over to your new rims. Post up pics when you finally get set up curious to see the rims, might be something I will be looking for down the road.
