Need your input
Old 10-19-2010 | 07:31 PM
MTP-FX4's Avatar
Need your input
Fellas,
Im looking at getting some Nitto Trail Grapplers saturday, 35x12.50x20. I have 2.5" coil spacers. WILL THEY FIT?? how bad will they rub? Thoughts?
Old 10-19-2010 | 07:44 PM
TheCrazyredneck's Avatar
do a search someone has this setup
Old 10-19-2010 | 08:08 PM
FX4SX's Avatar
youll have to do some trimming. but it should work
Old 10-19-2010 | 08:10 PM
MTP-FX4's Avatar
im up at school, with minimal tools. how time consuming is this ****?
Old 10-19-2010 | 09:16 PM
https://www.f150online.com/forums/wh...installed.html
try this hes got the same setup i dont think he did much trimming
Old 10-19-2010 | 10:12 PM
FX4SX's Avatar
you just need a hack saw and about 5 minutes. it will be the plastic on the lower corner of you bumper.
Old 10-19-2010 | 10:47 PM
UNC Lariat's Avatar
I just put some 295/70/18 (converts to 34.4 x 11.6) Trail Grapplers mounted on 18x9 XD Monsters on my truck this past weekend. I've got an AS 2.5 leveling kit and I had to trim about 1/4in off the plastic valence on the front. I also had to remove a screw on the rear portion of the front fender "flare" that was causing it to stick out an additional 1/2in. I put the screw through the outside (closest to the tire) of the fender "flare" and it increased the clearance by about 1/2in. I haven't taken it wheeling yet but I'll be surprised if I don't rub off road.
If you stick with factory wheels you should be ok with some trimming. On my truck and rims, I highly doubt I could fit 35x12.50s without substantial trimming. Just my .02...
Old 10-19-2010 | 11:07 PM
hawaiian boy's Avatar
Minor trim job and don't forget to post the pics.
Old 10-19-2010 | 11:44 PM
wandell's Avatar
Are you using the OEM 20's? The problem with the OEM 20's is that they have 6.5 inches of backspacing. This puts the edge of the tire really, really close to the upper control arm/ball joint. So close that some 12.50 inch wide tires with aggressive sidewall's will actually touch the upper ball joint. If the Grapplers don't rub here, you will be fine.
Old 10-20-2010 | 04:13 PM
Derrick@TireRack's Avatar
Former Sponsor
Will work like a dream. Just might have to trim a little on the bottom of the front half of the front fender.
Old 10-20-2010 | 07:42 PM
MTP-FX4's Avatar
Alright thanks for the input guys, i'll have pics up next week
Quick Reply: Need your input
