Original plan didnt work out... now plan B
I was originaly going to go with a Mamba wheel, but it didnt work out. I found Eagle Alloy series 063 that I like.... My truck is a 2006 FX4 with 275/65/18 and was thinking of going to 20x9 offest +20 with backspacing 5.725 Websites show going with a 275/55/20 tire but can I fit 275/60/20. I have an AS 2inch level kit in the front. Was looking at Cooper Zeon LTZ as the tire.
That should be fine. Those tires convert to 33x10.8. There are a lot of people on here that run a 2in leveling kit with 33x12.5 MTs on XD Monsters that have a +18 offset and 5.71 backspacing. I'm running 295/70/18 (34.4x11.6) with a 2.5in leveling kit on XD Monsters (again similar offset and backspacing) and I only had to do minimal trimming. Bottom line, you should have plenty of room.
Just my opinion, but whatever you decide, good luck to ya.
going from 275/65/18 to 305/55/20, will i need to do any trimming and will there be any rubbing with it being a little closer to the suspension? (I found a tire calculator online) Also I thought you have to stay within like 3% difference so that you wont mess up your gearing, is this true ?
