Tire Pressure
Old 10-22-2010 | 07:42 PM
Jared Lutes's Avatar
Tire Pressure
Looked at the tire pressure vs. temp table, but I am not sure. What pressure should I run my tires. Its around 50 degrees F, and I am on pavement only, usually speeds of 35 average. I am looking for the best pressure for my tires to last the longest. thanks.
Old 10-22-2010 | 08:09 PM
kingfish51's Avatar
Those are a LR E tire with a very high load rating (over 3600lbs). Normally for a LR E with a max of 65 I would say 45 and don't go below 40, but with those, I would say 40 and don't go below 35. 40 should give you all the load carrying ability you should need. for an F150.
Old 10-23-2010 | 04:57 AM
ok sounds good, thanks king
Quick Reply: Tire Pressure
