Rear of truck jumping when braking at 45+ mph
Here goes. Got this problem when braking. At beltway speeds when hard braking, back of truck jumps very bad. Faster the speed the worst jumping is to slow down. Even at lower speeds with light braking, it does it but not as bad. Replaced rotors and pads in the rear. Thought that was it. Still have the problem. The ebrake shoes look ok. A friend is telling me to check universal joints. One of them or both may be frozen up. It only does this when braking. I was wondering if anyone else had this problem.
2003 F150 4x4 5.4l. aBS brakes Thanks for reading. 11/1/10 today. I changed sensor for anti-lock brakes on rear end but did not help anything. 11/13/10 Replaced front rotors and pads. Replaced both universal joints. Had it checked with scanner. No codes. Still same problem.
Possible repair
I am a happy camper now. Bill
Yeah I know this is an old thread but I figured I had better update since I solved my problem finally and may help someone in the future. I got new rotors and pads for the front and did kinda like Webturtle said and I pulled the fuse on the ABS for a short bit then plugged it back in and voila!!! No more bouncy truck!!! I cant really say it was one or the other but I know the new brakes definitely played a part. My next step was gonna be replace the proportioning valve but it doesnt look like I will need to do that. Thanks for the help again F150online!!
abs/hopping in the rear when apply brakes
ok guys i just bought a 1997 ford f150 ext.cab 4by4 lariat the abs is kicking on for no reason i have replaced the front brakes and rotors and i noticed my back drivers side wheel cyilinder was linking so i replaced that figured the abs problem would go away but it didnt i half to leave the abs fuse out so the abs dont kick on and when i drive the truck for the first time of the day it seems like one of the rear wheels locks up and when im driving and go to apply the brakes it wheel start hopping i feel like im going to hit another car if i dont get this fixed i took it to a mechanic to check the abs problem out he said its cause it has the wrong size tires and rims the size is 285/75/r16 i dont think this would cause it it has a 4 inch lift please guys help me out
