brake pedal fade
brake pedal fade
2003 f150 2wd, this started about a week ago;
when braking the pedal feels fine then will drop just a little and then feels fine again, kinda like air is in the system, but it's not.
Brakes only have 15,000 mi front and 5,000 rear. had brake fluid changed at dealer couple days ago thinking that old fluid or air was the culprit but nothing has changed. when truck is stopped at idle the pedal has no fade at all and when truck is cut off the pedal hardens up like its supposed to, any body have any ideas???? much appreciated.
I only replaced the front brakes. All the new parts from autozone this time, solid rotors,ceramic pads, same as rear. Last set on front was an internet order.
The inside pad on the front driver side was wearing very uneven, like it was getting "hung up" and not sliding smoothly in the caliper. Just changed the pads and hardware first and that fixed the soft pedal for the most part but the rotors didn't feel right so I swapped them out too. $125 rotors, $55 pads, $15 hardware kit.
Still cheaper than taking it to the dealer and letting them solve the mystery.
![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
