What Do your Tires Measure up to? 35s /37s
Ok I cant decide on tire size! here is my delema,
05, Screw 4X4
I have about 8.5" ft and 4" rr (Real Measurement) lift, im running 35X12.50R20 Pro-Comp Extreme M/T and the spec says they should be 34.5" tall, they actually measured at 34.25 new and now they measure at 33.1" (almost bald).
I think they looked to small when new, let alone wore down the just look stupid IMO.
So here is the problem, some tire specs say they are actually 35" tall but they are never what they say!
I would like to get a true 35-36" tire but I dont know what to believe!
I measured a new 37" Toyo M/T on a Superduty and it only measured at 35.25"!
1 What do your tires Measure at?
2 What is the Measured lift on your truck?
3 Do they Rub (ie: any trimming)?
4 what about gearing?
sorry for all the questions but I like to know before buying!
Thanks for the help!
here is a pic!
the picture is a couple years old when the tires where new!
05, Screw 4X4
here is a pic!
thats what I thought! But I met A guy that Had new 37X13.50R20 on his super duty, he insisted the only measured 35" so I broke out the tape and Im confused they only measured 35.25! What the Hell?
Maybe its the heavier truck!
oh his wheel are 20X10
OK I got my answer!
I went down to the local truck lot that has all lifted trucks and measured 4 different sets of 37s on 20s and they all measures between 35"-35.25",(Toyo M/T, Nitto Mud Grappler, Nitto Trail M/T, Pro-Comp EX A/T)
and 3 sets of 35s on 20s measured 33.5"-34"!(Toyo M/T, Pro-comp EX M/T, Nitto Trail M/T)
So I guess I will have to go with a 35" tire that says 37 on the tire! LOL
maybe this info will help someone else aswell!
Really is that called gravity! and does this this include adding 12.2 atmospheric pressure at 5000ft of elevation!
Thanks Man I was unsure about this!
Thats why my tires are 1/2" wider than tall! HMM thats still only 33.5" for a 35, maybe thats where Atmospheric pressure comes in, the 14.7lbs at sea level or the 12+ at 5000 ft might be it! (Squish factor)
LOL
just trying to be a smart A&^!
I know that what they say and what is reality is always different! I was trying to see how accurate the manufactures specs are!
Thanks anyway!
LOL
Thanks anyway!
LOL. Don't know about atmospheric pressure, but you can be sure air pressure plays part in it. I run my tires at 40 psi while some guys run over 50 psi which will make my tires "shorter". I just think there are way too many variables to take into account if you are actually going around measuring differnt people's tires.
You are saying exactly what I was implying!
Again, I just want to know how accurate the specs are compared to real world, ya know with weight of the vehicle, gravity, atmospheric pressure, and tire pressure, didnt think about some people needing everything spelled out for them!
I didnt think people would chime in that have no experiance on what im asking!
I dont like the negative undertones some people always put out, but thats what works for some!
Thanks anyway! IM DONE WITH THIS POST!!
