Looking to increase brake performance
OK, I have a 2001 Supercrew F150, stock wheels and tire size. Ever since the vehicle was new I thought it had poor brakes. I have installed EBC Yellow pads and slotted rotors on all four corner, which has helped.
My problem/concern is with dry pavement I can stand on the brakes and they do not lock up (I know I have ABS but it does not kick in either). When I have attempted to lock up the brakes I notice that the pedal travels a LOOOONG way. I feel that the pedal travel is excessive (I have bleed the brakes until I am blue in the face, I also replace the fluid every four years). So, I think I need to move more fluid to drop the pedal travel. I am strongly considering swapping the master cylinder out for one with a larger bore. The current master cylinder has a 1.0625" bore and a stroke of 1.41". A 2004 F150's master cylinder has a 1.125" bore and a stroke of 1.44". I have also considered a 2001 F250 master cylinder with a 1.375" bore and a stroke of 1.40". I understand that increasing the bore will increase pedal effort but it will also increase the volume of fluid moved per pedal displacement. Is there anyone that has accomplished this and/or anyone with experience increasing brake performance.
FYI, I will be installing braided stainless brake lines with this swap.
That really sounds like the master cylinder went bad and its bleeding by. One way to check, which doesn't always work, is to pump up the pedal while the engine is off. If it bleeds down, you have your problem. Or do the same with someone else pushing the pedal. Go around the truck and inspect all the flex lines. Look for any swelling or bulges. If 1 goes bad, it could affect the whole system(taking all the fluid to fill).
How big of tires are you running? My buddies 2000 with 35" tires and stock brakes could still get them to skip.
Stock size tires, original, option rims - 17"
When you say pump the brakes, I am assuming you mean as you would have done before the advent of ABS. If I am pumping the brakes, why would the pedal bleed down? With the engine off, the brakes just act like non-vacuum assisted units. Wouldn't they behave just like they would with the engine on? Ie if they don't bleed down under normal conditions why would they with the engine off? Thanks for any insight.
You can feel it better when the engine is off. If the piston(s) are blown in the mc, it will bleed down and the pedal will hit the floor.
With stock tires, you should easily be able to stop with your face nearly in the wheel.
Does it pull to either side? Does it nose dive(no rear brakes)? Not dip the front at all(no front brakes)? Is the pedal really stiff(indicating the ABS might always be running)?
I said to check the rubber flex lines because when I went to get my '97, it got really soft all the sudden when I drove it. Both front flex hoses popped when I put it on the trailer. Only 100k miles.
Brakes are nothing to joke about. If something is ready to pop, your not going to stop real fast.
Planning on replacing flex hoses with braided stainless as part of my upgrades".
i read this post on another forum and it could work for you.
I have a 1999 F-150 ext cab 4x4, I have had a low spongy brake pedal for years. After replacing every brake component, master cyl twice, power brake booster, abs module, soft brake lines, calipers all around, rotars, pads, brake pedal, bleeding until I was blue in the face and many trips to the dealer and other brake shops regarding abs scan tool bleeding which is a crock of @#$% on this truck over the last couple of years, reading all kinds of posts of people going through the samething and also the post that says adjust the push rod between the master cyl and power brake booster ( DO NOT ADJUST THIS ROD IT IS NOT THE PROBLEM ) The rod from the brake pedal to the power brake booster is ''ADJUSTABLE" and is the problem for a spongy low brake pedal. While I was replacing the pedal brake light switch I noticed that the rod turns either way, to the left lengthens it and to right shortens it. The rod has very fine threads and take many turns for a minor adjustment, 30 turns to lengthen it for me which was about 1/2 an inch. Now I have 1/4 inch play with a good firm pedal and brakes that will stop on a dime inside your pocket. I am not saying that this is a cure for everones spongy low brake pedal but worked for me.
