Help!! 20x10 rims with 33's?
Okay I have a 2004 f150 4x4 and just ordered 20x10 rims with 5' backspacing
I have a 3inch lift my question is what all terrain tire will I be able to put on without rubbing with the level kit?
I would like to put 33's on I don't mind trimming a little...Also how far will these wheels stick out?
I know my Stock rims = about 5.5 backspacing and 7.5 inches wide Any help would be appreciated thanks again!
Those wheels will stick out 3 inches farther than your OEM wheels. You can fit a 305/55-20 (33x12.50) tire, but you will have to do some trimming because of the wheel width. As for tires, I'd suggest the BFG AT KO, Nitto Terra Grappler, Toyo AT, **** Cepek FC II, Mickey Thompson ATZ or Pro Comp Xtreme AT.
