2011 Lariat Limited Wheel Question
I just picked up a Lariat Limited about two weeks ago and want to get a second set of tires and wheels to use; the Limited 22's are sweet but want something differnet for winter driving etc. I would like to put on a set of 20's with tires in the 275/65R20 range for a little more sidewall than stock..
I am having trouble finding information related to offset, backspacing, & wheel width... Here is what I have got so far..
1-Talked to Tire Rack and they have no information on the new Limited and cannot make any recs...
2-Spoke with the dealer and they said the limited uses the same rotors and suspension as the King Ranch so I should be okay running a 20 inch wheel.
3-Used the tire size calculator and a 275/65R20 has the same diameter and width as the stock 275/55R22
Can someone tell me what the backspacing/offset on a stock 20x8.5 inch king ranch wheel is? I dont want them to stick out and like the stock profile. Also can I put on a wider wheel 20x9 or 20x9.5 if I change the backspace or offset. Last thing what about I wider or taller tire than the 275/65R20 I am looking at. I do not plan to do any type of suspension modes for extra height.
Thanks for the feedback.
