Closest size to 325/65/18 for 20" Wheels
Its time for a new set of rubbers for my truck and I have an 07 F150 SCREW. I am currently running 305/50/20s and they look tiny. I dont want a 33x12.5r20 bc i still dont think they are big enough. BTW i have an autospring 2.5 leveling kit and Ultra Lighting Wheels. Not sure on the backspacing and all that but they stick out just a little bit more than OEM. I wanna do something around a 34 inch tire but i want them to look fat and wide. I want something in comparison with a 325/65/18 but with a 20" wheel. I would love some feedback from someone please!!! Thanks
When nitto first came out with that tire size i mentioned i saw one on the ford lot with a leveling kit. They had to do some trimming, but they had a little less backspacing then you. Your look like they are around 5" of BS... i have mine in my gallery to compare. 20x9 with 4.5" or -12 offset. i have 305/55/20 TG's. And i wouldnt fill comfortbale doing any larger then that on my truck with just a leveling kit. with my wheels any bigger and i was going to get close to having to trim a little sheet metal.
http://www.1010tires.com/tiresizecalculator.asp
Dude, you gotta use the tire-size calculator.. The overall diameter on a 325/60-20 is 35.35" and on your 325/65/18 is 34.63".. you don't lose a lot of sidewall either moving to the 20 (7.67" for the 20 and 8.31" for the 18).. so this tire should be fine with no rubbing..
