Need help with wheels KMC monsters
Old 03-02-2011, 11:26 PM
Assault's Avatar
Hello Im new to this site. I just got a 2006 supercrew lariat and want to put wheels and tires on it. Looking a 20x9 monsters but want to know what tire will fit on it stock or do I have to put a leveling kit on it. looking at a wheel and tire package from wheelfire for $2039. Will the tires rub with 275/55/20. Thanks in advance.
Old 03-03-2011, 12:31 PM
wandell's Avatar
You didn't mention if you have a 4x4 or 4x2. That's a pretty small tire so you should be fine either way.
Old 03-03-2011, 03:39 PM
Assault's Avatar
Sorry it is a 4x4 and I had the tire size wrong. 285/50/20s is what comes with that package. Will it fit stock or do I need leveling kit.
Old 03-03-2011, 09:55 PM
wandell's Avatar
If you want a "street truck" look, I would go a little larger, like a 305/50-20 since you have a 4x4 and level the truck by installing lowering shackles out back.
If you want an "off road" look, I'd suggest a 305/55-20 and level the truck by lifting the front slightly.
Old 03-03-2011, 11:31 PM
runin1320's Avatar
I just put on a set of 20x10 Monsters with 33x12.50's tonight. Stock ride height and just had to do a little trimming and use the BFH tool on the rear of the front wheel well. Looks better in the light...I'll get better pics soon. I would think that the 20x9's would fit with no trimming on the stock ride.
Old 03-04-2011, 08:22 AM
Big_Smokey's Avatar
The price seems a little high for that small of a tire. Id check ebay before you purchase... those tires are tooooo small! 305/55 at least!
Old 03-05-2011, 09:36 AM
Assault's Avatar
OK first Question 305/55 does that equal 33x12.50. And runin 1320 thank you for the pics ur truck looks killer. I like to have mine set in a little futher. But maybe 20x9's would give me that Wish I new more about tire sizes. Anyone who have pic id like to see your set up. By the way thanks to every one on here this is a great site. My truck is the sandstone color do you guys think black wheels will look ok??
Old 03-05-2011, 10:34 AM
wandell's Avatar
Yes, a 305/55-20 is approximately a 33x12.50.
Old 03-06-2011, 10:48 PM
muddyfx4's Avatar
i went with a 20x9 rim and a 35x12.50 tire. TRIMMING REQUIRED!!!!!! but it sure looks good back spacing is 4.5 inches. wheels stick out an inch or so
Old 03-06-2011, 11:01 PM
I have 20x9 XD Monsters 5.71" BS and 33x12.5/20 Toyo M/Ts. Only rubbing is on the lower control arms at full lock in reverse and it doesn't rub bad at all.
Old 03-11-2011, 08:45 PM
Assault's Avatar
Hey Guys I pulled the trigger on some Monsters 20x9 wrapped in 305/55/20 nitto terra grapplers. Having 2.5 leveling kit installed Monday. Thanks for all the info glad you guys talked me into a bigger tires was going to get 275/55/20. Think these will look better. I will post pics when I get her done.
Old 03-11-2011, 09:37 PM
Big_Smokey's Avatar
you will be glad you did. should look sweet.
Old 03-21-2011, 09:55 PM
Assault's Avatar
So i got my wheels today. My question is do I need the hubcentric rings or can I go without. I called wheelfire and they said its lug centric so I dont need them. THe rings they sent me are to small so I want your opinion on this will I wreck something not using the rings. It seems to ride smooth so Im not sure.
Old 03-21-2011, 09:56 PM
Assault's Avatar
How do you post pics on here.
Old 03-22-2011, 11:24 AM
BLKMAGIC's Avatar
You can host them on Photobucket and then link them in this thread...or go in your gallery on here and upload them.
Quick Reply: Need help with wheels KMC monsters
