Wierd smell/pull
Wierd smell/pull
I was driving into work early this morning and felt my 04 fx4 pull to the right. I checked to make sure my tire was not going flat, but it is at normal press. Shortly after that, I started noticing a wierd smell. It kind of smells like battery acid. Everything else on the truck is checking good. No vibrations, sounds or anything abnormal other than the pull/smell. The truck pulls at all speeds with and without the brakes being applied. Could this be my brakes hanging up?
