Rockstars causing steering wheel shimmy?
Our trucks are called hubcentric it uses the center bore to keep the wheel on the hub some wheels come predrilled for ford and chevy so if the center bore is bigger than your hub it can't cause what your talking about if you need rings it takes the space out and does not make the wheels stick out. Pull your center cap off and see if there is another set of holes drilled and look at the center bore and see if there's a gap or its pretty snug if you can take a pic.
I agree, when I got my aftermarket wheels I had them balanced three different times and still had a shimmy, finally got them road force balanced at the Ford dealership and they are fine now. Seems to be more of an occurrence in 20" plus diameter wheels.
