Caliper piston problems
Just recently I changed my front brakes and found that the inner pad on the drivers side was so worn down it had hit metal while the outside one was normal. When I went to compress the pistons they were so tight they wouldn't budge, and when I released the bleeder valve only a few drops would come out. I finally got them to go down and finished the job but now they're back to sticking and my brakes are dragging bad. Anyone have any ideas on what to do?
Just had the same problem. Needed pads all the way around for inspection. Once finished, couldn't get the Front Driver's side to release. Smoked and Smelled for a week, MPG suffered, couldn't coast in drive. Bought an Aftermarket Caliper from Advanced Auto put on and it's back to normal.
Good Luck
Good Luck
Good Luck
Good Luck
