295/70/18 Nitto Trail Grapplers on 07 F150
Well after reading a ton of conflicting posts about wether these tires would fit without rub and if a negative offset would make it worse or not.......I went ahead and took the chance on them anyways. I thought I would post this with some detail for others also lost and confused if they should go bigger or not. NOTE: there was some work and a bit of frustration at first!
295/70/18 Nitto Trails on Moto Metal MO957 was what I finally settled on. So I put them on and prayed they would not rub. Never works for me.........only minimal rub on the front of the lower variance, however, plenty of rub on the rear of the front wheel well. And of course there is some small pieces of metal. After really debating wether or not I wanted to start cutting up the truck, I grabbed the sawzell and a good metal blade and dove in.
Surprisingly it went smoother than I anticapated and was not that difficult to trim. Here are some pics of before and after along with a few of what was trimmed. No rub at all with some clearance for articulation. I have also not noted any issues with rubbing the control arm.
Let me know what you guys think...
