Open Tire Pressure Discussion
If you look at the numbers, 40 is too low even for an empty F150 with most LR E tires. Especially at the front. Most LR E tires have a limit of between 3000 and 3600lbs. At 40 they are limited to half or less of that weight. An empty 2011 scab is going to run around 5500lbs empty, no passengers. With the biggest amount of that weight in the front. Those tires would be overloaded with 40 psi.
Personally I have run LR E tires at 50 with no problems with wear, and if carrying a load, I did not have to worry about adding air just to do it.
Also the recommendations by NHTSA is that TPM system would alert if the pressure drops to 46psi for a LR E with a max of 80.
http://www.nhtsa.gov/cars/rules/ruli...ule.html?name=
As for the Trail Grapplers, LR E 35", they have a max of 65 rather than 80. 35 is not as bad as the other suggestion, but is still too low. Discount had them about right, although they would have been better at 45 when loaded.
The 295/70R18 has a very high rating for a LR E (4080 at 80psi). You can run them at 40 and be good for even a loaded truck. ASlthough if towing, you may want to run them slightly higher (45) for sidewall support.
Each and every tire is different. You have to look at the numbers for each one to determine what the should be run at.
The problem with underinflated is that even before wear is evident, you may damage the tires. Where with overinflated, the worst that will happen is excessive wear (except when over the the tires max).
The fact that it is one of the recommended widths does help. Still, make sure they are properly inflated. I would start at 40 and go from there. I would not go any lower than about 37-38. Just remember that they are close to a mud terrain tire with an open tread (less rubber on the road in the footprint that other tires). Even properly inflated, they may wear quicker than something like the Terra Grappler.
Mr Kingfish...quick question to avoid this old man lots of searching (just lazy tonight)
LT275X70X18 Nitto Dura grappler highway terrain on 9" XD wheel...what would be a good pressure (starting) on an 07 FX4 Daily Driver no load or towing mostly ??
Looking at the specs, that tires recommended widths are 7-8.5". So in your case you may even want to go slightly higher than what is needed. I would start at 50 and see how they wear. Might be a slightly rougher ride, but to get better wear, you may need to go higher.
