brake pads installed at home????
when my truck went to the shop the other day...they wanted like 150 2 put in front brake pads....(parts included in price) i went out and got pads and said stick it! ima do it myself...followed this vid http://www.youtube.com/watch?v=36i-c...eature=related and everything came out A OK
![devil](https://www.f150online.com/forums/images/smilies/devil.gif)
I could have been the advanced "special-effects" in that video, but I didn't see a torque wrench (for both the caliper bolts and the lug nuts), anti-seize for the lug nut studs and the back of the pads, popping the MC reservoir cap (the air / fluid has to go somewhere when you're depressing the caliper piston), or turning / replacing the rotors (2WD also plan on re-packing bearings).
I wouldn't hang my hat on everything you see on-line. There's still something to be said for Chilton's / Haynes / experience.
![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
I wouldn't hang my hat on everything you see on-line. There's still something to be said for Chilton's / Haynes / experience.![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
Should have re-packed the wheel bearings too.. ![Wink](https://www.f150online.com/forums/images/smilies/wink.gif)
I get away with not turning the disks every other pad change... Then I just buy new disks..![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
Nice job none the less... I think I did my first brake job when I was around 16 and it was a learning experience to say the least!
I did my rear drums last year... Now, that is a job! I wish I had rear disk brakes!
Lots of parts..
![](https://www.f150online.com/forums/members/mitchf150-albums-mitchf150%27s+pics-picture56595-new-springs.jpg)
But they do go together..
![](https://www.f150online.com/forums/members/mitchf150-albums-mitchf150%27s+pics-picture56593-drum-after.jpg)
Mitch
Lots of parts..
Mitch
Yeah, but unfortunately even the rear disk brakes use drums for the e-brake. Not normally a problem unless the reason you're working on the brakes is because you forgot to release the e-brake before driving 20 miles on the highway to go to work (and the warning light on the dash was inoperative) ![devil](https://www.f150online.com/forums/images/smilies/devil.gif)
