99 F150 master cylinder leak
Greetings fellow Fordians...
I've developed a pretty good leak from between the Master Cylinder and Power Booster. Found a small puddle under the truck this morning. I've not lost any brake pressure, and no signs of failure...just a leak so far. It's apparently been leaking for weeks now from the saturation around the cylinder, lines, and such . Master Cylinder was replaced about two years ago...PB is original still. I'm hoping the O ring is just bad. Can anyone tell me if a leak like this could be as symptom of the MC or PB though?
thanks.
thanks.
