deciding on 2.5 inch or 3 inch lvling kit
Search level and u will get tons of pics. Look under suspension instead of wheels/tires. Not sure what year your truck is but 3 inch is not soo good on the cv angles. I wouldn't go any more than 2.5. I put 2 inch on my 06 and it sat level. If 04-05 the 2.5 should get u there. I went with nearly 33s (32.8). Even with the 2 inch u could fit 35s with proper offset/bs wheel.
[IMG]
[/IMG]
[IMG]
![](https://www.f150online.com/forums/members/jerrybizzle-albums-2+inch+autosping+level++air+lift+rear+bags-picture160894-imag0066.jpg)
You have a lot of options with a 97-03 4x2. You can gain up to 2 inches by using Daystar coilspring spacers. You can gain another 3.5 inches with replacement lift spindles. A 3 inch Performance Accessories body lift is another option. Of course you can combine all three for 8.5 inches of lift relatively inexpensive.
Been working, but I will have all my new parts on the truck on Friday, putting a 3" leveling kit in the front with a 1" block in the rear with 33x12.50x17 BFG ATs, should have time to complete it and post somewhat decent pics by friday, will let you know, I have a 08 STX 4.6L 4x4, newer and completely different since its a 4x4, but it might give you an idea, although these components on your truck would look very different
