Trail Grapplers Started Rubbing
If anyone remembers about a year ago I got a set of 295/70/18 Nitto Trail Grapplers. When I got them there was no noticeable rubbing, I did not feel, hear or see it in any way. Recently I rotated my tires, and this may just be a coincidence, but now my tires are rubbing the sway bar on both sides at full lock. Its not a show stopper or anything, but I can visibly see it, feel it and hear it. The air pressure is good, running 45PSI, tires still ride great, are wearing even, I have no vibration or shakes in the ride or through the steering wheel at any speed. Any clue why they would have started rubbing now? The only thing I can guess is the sidewall has softened causing a little more of a bubble or wider footprint that was not there when new. I have roughly 15K on them.
You are correct about the two different sidewalls, but the aggressive side is turned out on all four, so that's is not the case. Not to mention these tires have been on the front before because this is not the first time they have been rotated.
i do not really have an answer to your question. i am however looking at that tire. how do you like them? do they do well in snow and rain?
also do you have them on stock wheels? if so could you measrue the tread width on the truck and let me know what it is? i currently run 305/65-18 BFG's and they are pinched pretty good so i was thinking the 295/70 may give me about the same measured width on the truck. ( the original 275's were just plain weeny looking )
Thanks guys, I will check out the joints. The truck only has 47K on it and I would say 25K of that is without a leveling kit. I hope my ball joints are not shot already. I did glance at them the other day for any obvious signs of wear & tear and visually they looked fine. I will pull the tires and do a more thorough inspection and see if that turns up anything.
Finally discovered what I think it is. Appears that the stop on the LCA that the spindle bumps against at full lock has worn since its steel on aluminum. Since it wore down I can now turn just a little more which caused the tires to rub on the sway bar.
