How big of a lift would I need to fit 24s?
Old 05-10-2011 | 06:36 PM
carson123987's Avatar
Hey guys, I have a '07 Screw and I'm looking to throw some 24" DUB Mambas on it. I already have a leveling kit installed and am wondering how much of a lift I'd need to fit 24s with a decent size tire. Any help is appreciated. Thanks!
Old 05-10-2011 | 06:47 PM
06yz250f's Avatar
kid i went to school with had an 06-07 2wd with a small drop (shackle drop IIRC) and 24's.
Old 05-10-2011 | 11:04 PM
jerrybizzle's Avatar
U could fit them with 40 series tires as is.
Old 05-10-2011 | 11:23 PM
wandell's Avatar
Please tell me you don't want to lift your truck to run a street tire on 24's.
Now if you want to lift it fit a 40 inch mud tire on 24's, that's awesome!
Old 05-10-2011 | 11:25 PM
06yz250f's Avatar
and if so, you need atleast 11-12" of lift
OR
Popped collar status
Old 05-10-2011 | 11:46 PM
HighOn22's's Avatar
I had 24's On a 98 Ranger with thr same size tire guys were running on full-size trucks. Think it was a 295/35, not to sure. Side wall was around 2.5"-3" tall. Only place I rubbed was at full turn
Old 05-11-2011 | 03:10 AM
Yeah i was thinkin gettin 35s with the rims. Just wanted to make sure there wouldnt be any rubbing. What about 26s?
Old 05-11-2011 | 08:42 AM
Galaxy's Avatar
You don't need any lift to make any size wheel fit...it's the tire diameter that determines everything.
Old 05-11-2011 | 10:36 AM
graygoblin's Avatar
that leveling kit should be enuff, depends on what size tire u wanna use. if u lookinf for a 37" or 40" tire than start looking at 6"-10" lifts
Old 05-11-2011 | 12:13 PM
rrozell's Avatar
Rims size doesnt matter, just tire size. To run 35's you need 6" lift if 2x4. not sure who makes a 35 for a 24" rim though.
Old 05-11-2011 | 02:14 PM
brazzeal15's Avatar
Look at Nitto Terra Grapplers... They make a 305/40/24 for you.. Its a 33" tire but you wouldnt want much more or you will rub due to the typical high positive offset of "DUBS".
Old 05-11-2011 | 02:44 PM
graygoblin's Avatar
i think they make a 315/50/24 as well which is close to a 36". I think trailgrappler makes 35 for a 24" rim
Old 05-11-2011 | 03:50 PM
http://www.rimsntires.com/wheels/dub/mamba_b.jpg
http://www.elementwheels.com/proddet...prod=dms139chr
These are what they look like to give an idea. The reason i dont want 26s is because people have said it destroys your brakes.
Old 05-11-2011 | 04:24 PM
graygoblin's Avatar
when u want big rims u gotta upgrade brakes and rotors to accommodate for the rim size, thats a easy fix! And 26s on a truck isnt that bad, i would just get some 4:10 gears and be just fine bro
Old 05-11-2011 | 04:26 PM
graygoblin's Avatar
24s always look good on trucks,with a nice deep exhaust, truck should be nice
