XD797 Spy Wheel
XD797 Spy Wheel
Recently put a AS leveling kit on my truck 05 f150 fx4 sits level now. Anyways looking at buying a set of XD797 Spy Wheels 18.9 and buying a 33x12.5 tire (mud tire) dont know what brand yet. What I wanted to know if I would have any problems running this setup on my truck and is anybody else running these wheels? How wide are the factory wheels?
XD Series XD797 Spy Wheel
18x9, 6 on135 Bolt Pattern
Backspace 4.53 in.
Max Load = 2200lbs
Finish = Gloss Black Machined
Hubcentric = No
Offset = -12 mm
Backspace 4.53 in.
Max Load = 2200lbs
Hubcentric = No
Offset = -12 mm
I didnt plan on running anything larger than 33x12.50. Since these wheels will stick 2.5 out farther, do you think 33x12.50 on that wheel will rub at full lock? I know the mud tires (measures 31 inches tall) I got on the factory wheels are probably about 2 inches from rubbing the inner fender at full lock. Just dont want to pay almost 200 a wheel and not work with what Im looking to run.
good luck - those are nice wheels!
