Cannot get firm pedal
I have a 97 f150 2wd. The brakes worked fine before my grandfather blew a line just before i bought it from him. I repaired the line and bled the brakes, a half dozen times, still soft pedal.
I read some forums and decided to replace the master cylinder, rubber lines and all the older rusted lines. Bled it a few more times after that and still have a soft pedal that goes almost to the floor.
I've changed lines and bled brakes on multiple vehicles and never had a problem, I'm stumped.
If anyone has an idea the info would be greatly appreciated, I really don't want to pay for the dealer to fix it. lol.
Does this truck have rear drum brakes? If so, they could be way out of adjustment.
Also, I have seen this issue on GM vehicles that have been run dry of brake fluid. The fix was to actuate the ABS module (to remove air) during a special brake bleed procedure with a GM scan tool. Not sure if Ford is the same or not.
Good luck!
Good luck!
It does have rear drum brakes and they are adjusted out so they barely drag the drum. I have bled over a gallon through the system and have clean fluid coming out of the bleeders.
I also bench bled the master cylinder until there were no more bubbles coming out.
I've tried pump & crack, gravity bleeding and vacuum bleeding and nothing works.
Is it possible for a vacuum leak in the booster to cause issues like this? Or maybe just air stuck in a junction/abs unit that doesn't want to come out?
I was also told by a guy at work that he jacked the rear of the truck up and opened both bleeders and the master cylinder and gravity bled them like that, making it easier for the air to escape and then doing the same with the front. He said it fixed his, but that was on a chevy 1500.
It could be air in the ABS unit... you will need someone with the electronic tools to cycle the ABS while bleeding if that is the case.
If you want the brakes to feel better, perhaps try replacing all the flex lines on the truck. I would do this before paying someone to cycle the ABS.
