Another "phantom" ABS engagement issue - with a twist?
Old 06-04-2011 | 03:04 PM
OhioLariat's Avatar
OK, I had originally brought another thread back from the dead, but it's not really the problem I'm having, and I have a few more ideas, so I thought I'd start a fresh topic instead.
My truck ('99 4WD) recently began "ABS-ing" occasionally when slowing down to stop, usually under 5-10 MPH. It occurs only once in a while, and is not repeatable. Turning or making straight-line stops does not seem to make a difference.
I'm planning to pull the ABS fuse for now because sometimes, that extra 6-10 feet DOES make a difference!
I've read that the first thing to look at is usually the RABS sensor, then the fronts, and to check the hub tightness, etc.
BUT - I also saw where one person mentioned bad rear diff fluid, where the poster mentioned "wheel-skipping" problems, and other issues with the diff, which got me to thinking...
My rear end has more lateral play in it than I'd like (nearly 1/8", it feels like), and often makes a clunk when turning across uneven surfaces when the back end "shakes" from side to side.
This has me wondering if the clunk/free-play and the ABS issue could be related. They did not start at the same time, but still...
Any input will be appreciated. Thanks.
Andy
Old 05-05-2016 | 10:29 AM
OhioLariat's Avatar
Clearing out old subscriptions, and getting ready to do tings to a sonne-to-be-new-to-me '03, and came across this post.
I thought I'd update to let any future searchers know that this was resolved with replacement of the front hubs. After a few years of running no ABS fuse, a wheel bearing started making noise. Replaced the hubs, re-installed the ABS fuse, and all was good.
Andy
Quick Reply: Another "phantom" ABS engagement issue - with a twist?
