Another rim offest/backspace question! motometal 951
im ordering moto metal 951s in black tonight. 18 x 9s. i have 285/65/18 duratracs on stock rims ill be wrapping around the new motometals.
anyways i need help fast!
what one is best?
offset: -12 backspace: 4.53"
offset: 18 backspace: 5.71"
offset: 30 backspace: 6.18"
i want them to stick out just a hair wider but not stickin out like crazy.
which is which, higher number closer in it is? or vis-a-versa?
i think 18 is what i hear is the right one but how much of a differance is the 18 from the 30?
any help appreciated!
what one is best?
Sounds like u have the right idea. The negative offset and not as much bs would stick out significantly. The 18 would stick out a half inch or so farther than the +30. I am pretty sure the +30 would be similar to stock specs. If u want them to stick out a bit would say go with +18. Seems like a happy medium. The -12, +18 and +30 are in millimeters. So the difference between +18 and +30 is mainly in the backspacing.12 mm isn't that much difference. Maybe 1/4 inch. Convert if u want for more accurate actual difference. .47 inches difference in bs plus the 12mm diff in offset would be your total difference between the +18 and 30.
So if I get the + 30 backspace and I have 285/65/18 duratracs which are technically 33s, will they rub when turning. I don't want ANY rubbing!! If I'm clear and have plenty of room with the + 30 ill get them cause I don't want them to stick out much further! So +18 or +30? Still unsure and need assistance!
