2010 FX4 wheel fitment question
Called the local tire store about aftermarket wheels (Diamo 17K) in an 18x10 -neg 12mm offset 6x135 bp. They said these wheels would not fit my truck without a 6 inch suspension lift? They did not ask what size tire I would be running only the wheel would not fit. This is a fairly common wheel size for this site, and I plan to only run a 33x12.50 with a Rancho 4" lift.
I don't see why this will not work? Maybe I'm missing something and want to make sure before I order. Thanks
You should have no problems running a 33/12.50 on that wheel with a 4" lift. The Rancho tends to lift a bit more than 4" (if I remember correctly) so I'll bet you could fit a 35/12.50 with moderate trimming. Not saying that's what you want to do but it should make you feel a bit more comfortable about running 33/12.50s. I can tell you that with a 6" lift and 35/12.50/20s (Trail Graps too so they're a big 35/12.50) on those wheels I rub every once in a while. I could do more trimming and solve most of my rubbing but it only happens occasionally so I'm not really worried about it.
I've measured before but I can't remember the exact dimensions. Just guessing off the top of my head I would say they stick out about 3" in the front and a bit less in the rear due to the increased track width of the Fabtech lift.
Here are a couple pics of the stance with these wheels, 35/12.50/20 Trail Graps and a Fabtech lift:
