Brake Pad & Rotor Replacement Question
If this is inline with your other post, and you have 30k on the pads, I would go ahead and put new ones on there. Overall pads are not that expensive, why you are in there doing the work might as well replace them. You will not have to worry about any funny wear or negative side effects. If the pads were newer I would say do not worry about it, reuse them.
What are the potential problems with changing rotors and reusing the same pads?
I guess the main thing to check is make sure the pads do not have any odd signs of wear and the surface is good. Bedding the pads to the rotors should help eliminate minor variances where the pads are not flat. If you have oddly worn pads you are not going to make flush contact with the new rotor resulting in some uneven wear and loss of stopping power.
I am not saying you cant reuse them, but I would take a minute to examine their condition before throwing them back on there.
If it were me, I'd put on new pads when putting the rotors. Heck, I replaced (upgraded) the rotors when I had to replace my pads.
Just makes sense to me if you're going to have it all torn apart anyways and it won't take hardly any extra time. Then you'll be good for another ~40k or more.
- NCSU
- NCSU
