ABS light, no codes.
I will admit that I haven't done a search so forgive me if this has been discussed a hundred times before but my back is against the wall as we are leaving for vacation on Saturday.
Just received my CTS and installed a few days ago. My ABS light has been coming on intermittently for the last couple months and I thought I would be able to read a code with the CTS. I go in to diagnostics and read DTC's but it shows no trouble codes. Could the ABS light come on without setting a code or am I doing something wrong?
Obviously this issue won't keep us from leaving for our trip but I would rather be able to make the repair before we go if possible.
Any advice would be appreciated.
1999 F150
1999 F150
Obvious question, but may not apply as I think you get the brake warning light and not the abs when fluid is low, but check it if you have not.
Chances are though you probably have a dirty ABS sensor, or even a sensor that is on its way out or bad. Do a search on cleaning ABS sensor, should help you out.
Yea I thought about possibly picking one up on our way and changing it out when we reach our destination. Inexpensive and easy swap so worth a try.
