tire size in mm help
Your width of rim will affect the revolutions per mile. I put in the generic number for mine and adjusted from there. Now my speedometer matches the gps mph. 605 would be a starting point. If your speedometer reads fast change it to 610 or so, if slow change to 600. Continue adjusting till it is dead on. Here is the link.
http://www.1010tires.com/tiresizecalculator.asp
And I just flatout misread. Mine asks for revs per mile. The tire calculator will tell you mm as well. But that will just be a starting point as both squish and rim width will slightly affect the overall size of the tire.
