lifted truck, now what to do about spare?
Old 06-29-2011, 07:03 PM
Get a good M/T and be careful with pot holes and such. I haven't had a flat in years, the Toyos on my old truck were damn awesome, but being as the spare lock seized it would be a pain to get the old spare down anyways.
Old 06-29-2011, 07:20 PM
Id just upgrade spare to 33 so you'd be closer to the right size if something happened, and used 33s are dime a dozen
Old 06-29-2011, 08:20 PM
Galaxy's Avatar
Well, here's the issue with a 33". If you're not going to match it to what's on the truck, you might as well leave it stock. Anything but accomplishes nothing. Putting a 33" is still off, and if it's off it's off...33", 27", doesn't really matter. It's still gotta go on the front regardless. Now you're just hauling around extra weight for no good reason at all, plus the potential to get it stuck as mentioned. Just a thought. It's not horseshoes...close doesn't count.
Old 06-29-2011, 09:21 PM
but having a 33 on as a spare would about be the equivalent of a kiddie spare for a sedan
Old 06-29-2011, 09:31 PM
infantry_18's Avatar
hey thanks for askin this i was wonderin the same thing. do they make atire tailgate type-o-deal like them jeeps got? or somethin similar?
Old 06-30-2011, 12:26 AM
fireman137's Avatar
A mismatched spare isn't a giant problem as long as you're using it for what it was intended for - getting your vehicle to somewhere close to fix the original tire. People who ride around for a month on the donut are idiots.
The biggest caveat, though, is if you have limited-slip rear. With a limited-slip rear and mismatched rear tires you'll tear up the differential. If you have to run a mismatched tire run it on the front axle in 2wd.
Old 06-30-2011, 04:02 PM
7lug's Avatar
Originally Posted by fireman137
... If you have to run a mismatched tire run it on the front axle in 2wd.
Just musta missed Galaxy's post completely lol...
Old 06-30-2011, 06:54 PM
BigBlue37's Avatar
Looks like they do.....check em out http://www.tiregate.com/hg_series_0.shtml
Old 06-30-2011, 08:28 PM
thats damn nifty there thanks, lil expensive, hell i might fabricate one f the tire carriers like the jeep hitch style
Old 07-01-2011, 12:09 AM
hardrock3742's Avatar
thanks for all the good info so far guys
Old 07-01-2011, 12:30 AM
fireman137's Avatar
Galaxy said what not to do, I just explained why.
Old 07-03-2011, 11:40 AM
MossyOak3006's Avatar
Get a used 35 and put it on a crappy wheel that has enough backspacing to fit. that's what I did. Then I stood it up against the side of the bed and attached it to the bed rail with 2 bungee cords. It worked real good for me and It costs a lot less than any kind of rack haha. It never slid around or fell over either
Old 07-03-2011, 02:15 PM
hmmm, not a bad idea mossy.....If I ever go offroading thats definitely what Ill do.
Old 07-05-2011, 09:42 AM
D's984x4's Avatar
If you do fab one, Infantry_18, do a wirte up on it with the specs and all that for everyone to see. There will most likely be some other people interested.
D
Old 07-05-2011, 10:10 AM
i will for sure do that...it wont be for a lil bit but i got 2 friends here on base that are interested and wanna help so next cpl months should be doin it for sure for you guys....haha first custom job wish me luck
Quick Reply: lifted truck, now what to do about spare?
