ABS light comes on
ABS light comes on
ABS light comes on with slightest right steering input. If I shut truck off light goes out and will stay out whether I drive forwards or backwards, but ANY right steering input causes ABS light to come on. As a side note, 4x4 will not engage, either.
I had new front hubs installed 1 or 2 months ago, and I've driven the truck very little...say 3 or 4 times a week, since then. Given that it takes right steering input to trigger fault, I would guess that rear sensor is ok and the problem is somewhere up front.
As MossyOak3006 said, make sure the plugs are connected tightly, make sure the cable isn't getting pinched somewhere, and if you can get to it, press down on the abs sensor on the hub to make sure it's seated correctly.
I'm having this issue as well, although my ABS light is constantly on.
