Brake Judder
Regardless, sounds like you should have a shop inspect the brakes asap. They will be able to tell you what's up in about 10 seconds...
Be safe - Get'em checked and replaced if need be.
x2, have them checked, or do a complete over haul which is what you should do anyways. New calipers, performance rotors and semi-metallic pads. I love mine.
https://www.f150online.com/forums/20...hawk-pads.html
What did it cost and what did they change if i may ask and i do so because i am having mine done today on my 2004 F150. First brake job on truck with 56k and man i was shocked. Rear 90% gone, front 80% gone, All 4 rotors need to be replaced. Sweet. $1250 but that was also having passenger side power window fixed(regulator) and he is not using OE brake parts.
