Im gonna try and explain this. Say if i have a 35/1250/17 tire vs a 35/1250/20 tire. Will they take the same amount of power to rotate or will the 20" be lighter cause there is less tire?
The actual circumference (increase radius arm length -> hub(center) to tire tread) of the tire makes a big part for torque reasons, not just the weight of the tire. Chances are you will not see a noticeable difference between the two.
