Will 2004 17" 7-lug fit 2001 16" 7-lug?
Check this thread. Seems they will work. Read reply from beltloop.
https://www.f150online.com/forums/wh...g-pattern.html
Nope it won't work
The offset on the oem is -15mm, offset on the 2004-2010 wheel is 44mm. I tried fitting the wheel on the hub with no tire. There is about 1/4" clearance between the wheel and the upper arm, less than an inch between the edge of the whell and the ball joint. So, although the rim fits over the hub and brake, it doesn't provide enough clearance for the tire.
