Is it safe to run 37's without re-gearing?
You can do it, but its just going to cause trouble and be cheaper to buy gears instead of a tranny. Especially if you have stock 3.55s, I would not suggest doing that at all. If you have 3.73s, thats not as bad, but still not great. Your gas mileage will probably be around 8 mpg, your tranny won't last very long, and the truck will be slow.
Well being that we have no info on your truck like year and engine it's hard to say. That being said I have been running 37's with the stock 3.73's for 25k miles and average 13 mpg. I take it easy, yes it's slow but it's a truck so I don't really care. I will be re gearing soon. But, take it easy and you should be fine. One thing that helped a lot with taking it easier on my transmission was upping the shift points by a couple hundred rpm with my tuner. By doing so it cut down the transmission trying to find the right gear and shifting to often.
