33-13.5-18 fit?
You could not do it on factory wheels, the tire is too wide for the wheel and would almost guarantee the clearance issue mentioned above - hitting the balljoint on the UCA. With an aftermarket wheel with the correct offset they would probably work, but expect some rubbing. I also agree its better to stick to a 305 or 12.50 series tire.
