OEM sizes for 3.55?
Old 09-13-2011 | 08:48 PM
SparkYZ's Avatar
OEM sizes for 3.55?
What were some of the OEM sizes available for trucks with 3.55 gears?
I've got a 2011 XLT 4x2 with 3.55's, currently running a 29'' tall tire, curious if a 31'' will make a noticeable difference in power.
Old 09-13-2011 | 08:54 PM
Longshot270's Avatar
Slight decrease but not much. That is the change I made.
Old 09-13-2011 | 09:32 PM
pizzaman711's Avatar
You'll barely notice it, I went from 29" to 35" with 3.55 gears and it's not even that bad.
Old 09-13-2011 | 09:54 PM
SparkYZ's Avatar
Well I'm stupid...
I went and looked at my tires, they are actually 235/75/17...
On online tire calculators that's a 30.9'' tire, does that sound right?
Old 09-13-2011 | 09:59 PM
My stock Pirelli's are 275x55x20 which is close to a 32" tire. Put on some 305x55x20 Nitto's 33" and the 3.55's handle them OK.
Old 09-13-2011 | 10:09 PM
SparkYZ's Avatar
You had 32's stock with 3.55? Just confirming
Old 09-13-2011 | 10:16 PM
Yes I did. I then went up to 33's. These are the 33's on stock 20's.
Old 09-14-2011 | 05:20 PM
rmp213's Avatar
I had 3.55 gears on my '95 and ran a 35x12.50 with them and it still had plenty of power. My '06 has 30inch tall from the factory but you'll hardly notice a difference if anything at all going to a 31 or a 33..if anything your mpg will go down a bit, but not much
Old 09-14-2011 | 11:11 PM
tbear853's Avatar
2007 FX4 with 3.55 gears and 275/55-20 factory fitted Perelli Scorpion ATR tires, 31.9" OD.
http://www.1010tires.com/TireSizeCal...bmit&reset=yes
Quick Reply: OEM sizes for 3.55?
