Warped rear rotors also??
I just replaced the rotors and pads on the front of my 04 F150 because they were warped. This summer I had the brake controller go out when we were going camping, so I to pull our 5000 lb camper and 500-600lbs in the bed for about 120 miles with just the truck brakes.
Now after replacing the front pads and rotors the steering wheel shake is completely gone. But when braking I still have the warped rotor feel through the seat of my pants and also very slight feed back through the brake pedal. The only thing that I can come up with is that the rear rotors are warped also. What do you guys think?
Brake lines or line is shot. Over expanded, broken down on the inside and now to restrictive to control the twin piston system equally. Small pieces also compromise flow. ONE caliper piston has applied pressure vs both, equally any way. This over heats the hardware, disfiguring/warping along with other front end problems.
IMO, all Ford truck lines should have received braided lines. At the very least on the front. Unfortunately, they have not.
-Derrick
on
I got dimpled and sloted rotors from Brakeperformance.com, I love them so far! But then again I only have about 100 miles on them too. I was thinking about waiting until spring to do the rears since in another 6 weeks or so the truck will be parked until the snow is gone, but I think I may do them yet this fall.
Just a quick update, I ordered the new dimpled and slotted rotors and premium pads 2 weeks ago for the rear of my 04 and also for the front of my wifes 05 Focus. On the Focus, WOW!! What a difference, although the stockers had over over 117,000 miles on the original set.
But back to my truck. I had a local garage install the rears on my truck yesterday. When they tore into it they found the drivers side rear caliper was froze up, which is what caused the rotor to warp. Parts and labor from the shop was $140, 70 for labor (installing the new caliper, rotors and pads) and $70 for the new caliper. The pads and rotors were $230 shipped. The truck feels like it will stop on a dime now!! Very happy with the whole set-up!!
