Will this work
Will this work
Hi all
I have a 2011 f150 4x4 and the tiny stock tires just are not doin it for me I have done a lot of searching and have not found any info on the offset I am looking at the wheels are 18 x 10 -6mm offset 5.25 back spacing the tires I Plan on running are a 285 60 18 will I have any issues with that low of an offset? I will be putting a 2" level kit on the truck at the same time
I am looking for a little bit of a wider stance and a tire that Is wider and taller than stock I'll deffinatly look into the 285 65....I won't have any rubbing issues with this set up? I haven't found a whole lot of wheels I like and that is the only size they offer in an 18"
Thanks guys for the help
