Need help with offset and backside setting
so now if i have a 17inch rim and 9 inches wide with -12 offset so if i have the same wheel but with 0 offset wich would stick out further? and do they make postive offsets ? if they do which stick out further positive offset or negative? What is backside setting?
You can't get wheels with a low offset and a high backspace. The lower the offset gets, then the lower the backspace gets. Most wheels with -12 offset will have 4.5" of backspace. As you go up in offset, the backspace will also go up. As jerrybizzle said, the higher you go with offset and backspace, the wheel will be tucked in more.
