03 brake job and hub replacement
I have a 03 4wd I would like to change brake pads and rotors on. Iwas reading my chilton manual and it says to remove about two-thirds break fluid from the master cylinder. that part does not make sense to me. Do any of you guys do that step to replace brakes?
the idea is if you've been topping off the fluid you have more fluid then your system can hold when the calipers are all the way. But if you havent been topping off the fluid you probably should be fine without doing anything.
Question tho, when was the last time you flushed the fluid? Its probably due for a full system flush, why not flush and bleed the brakes while you've got the wheels off?
I'd flush the fluid, drain ALL the fluid from the master cylinder (siphon off the fluid), then do the brake job. Siphon off the fluid pushed back into the master cylinder (should be empty now). Put NEW fluid in and flush the brake system (same procedure as brake bleeding). Be sure to buy plenty of fluid (I'd get 2 32oz bottles, less than $10 total at Walmart).
I did a write up for a 2003 2wd, somewhat similar to your truck
https://www.f150online.com/forums/ar...ighlight=write
Oh and you're definitely due for a brake system flush
