Quick question before ordering! Will this fit?
Old 12-16-2011 | 12:45 PM
Damn Dirty Ape's Avatar
WIll this fit a 2011 FX4? It seems like it would.
http://www.summitracing.com/parts/KMD-77829066735/
That's the closest I can find to the factory 20's I have now. Looks like the only difference is a +35 instead of a +44mm offset.
Something I'm missing?
Old 12-16-2011 | 12:58 PM
kingfish51's Avatar
No, according to the site, those are 6x5.5" lug pattern. You need 6x135mm. As long as you get that you should be okay.
Old 12-16-2011 | 01:53 PM
atr04screw's Avatar
At the bottom of the page it says the wheel pattern is 6x5.5" and it says 6x135mm. Just make sure it is a 6x135mm bolt pattern when you order, and it will fit. That is about as close to stock offset that you are going to find.
Old 12-16-2011 | 02:40 PM
Was also finding same part # on amazon and says 6x135 so it should be golden. Thanks
Old 12-18-2011 | 06:22 PM
JC10380's Avatar
Check out the ship date, it's over a month out. Just a heads up, and those rims are badass.
Old 12-21-2011 | 04:55 PM
BLUEforLIFE's Avatar
Wheels are sweet, but if you plan on going offroad, you might want to consider an 18 for sidewall protection.
plus both tires / wheels are quiet cheaper in 18"s
check out my pics for reference.
good luck!
Old 12-22-2011 | 06:55 PM
The above +35 with the 6.3 backspace fit EXACTLY like the 20" gunmetals. They come out the same amount when gauged with the fender flare.
Awesome.
Quick Reply: Quick question before ordering! Will this fit?
