Yes or no to wheel spacers?
I got some 1.5 inch wheel spacers for my 2001 sepercrew and when i put just the front two on to see how they looked,but when i drove witht them theymade awful vibrations! do you think with the rear ones on as well that i would still have this problem? i love the way they look but if there going to be dangerous then i dont want them. Thanks
General concensus is to walk away. However, there's tons of guys posted up that have been using them for quite a while with zero problems. One thing I've noticed from time to time around here is a lot of guys saying don't do it that have never used them and the guys reporting no problems are experienced with them. Problems with them seem isolated, so do your own homework and make your own informed decisions and risk assessment. Long story short, you'll most likely get nothing useful from this thread beyond a 50/50 split on using them or not. If you use them, find some quality ones that replace the studs. There are quality ones out there for sure.
The ones that people seem to have success with DID NOT come from ebay. So, if yours did, then get rid of them and look for a descent set from a reputable company that makes them. A good set of 4 will be $300+, so most people just end up buying a new set of rims with less backspace instead
General consensus is to walk away. However, there's tons of guys posted up that have been using them for quite a while with zero problems. One thing I've noticed from time to time around here is a lot of guys saying don't do it that have never used them and the guys reporting no problems are experienced with them. Problems with them seem isolated, so do your own homework and make your own informed decisions and risk assessment. Long story short, you'll most likely get nothing useful from this thread beyond a 50/50 split on using them or not. If you use them, find some quality ones that replace the studs. There are quality ones out there for sure.
The ones that people seem to have success with DID NOT come from eBay. So, if yours did, then get rid of them and look for a descent set from a reputable company that makes them. A good set of 4 will be $300+, so most people just end up buying a new set of rims with less backspace instead
I don't recommend them, but if your gonna get them spend the money and do it right, you don't want a wheel falling off going 60 down the highway because you wanted to save some cash. Expect to spend at least 300 for a decent set of them. But if your having a vibration that's definitely a bad sign and that means you need to return them and get either the right ones or different wheels.
You are stacking wheel spacers? Ay......... I don't know how great an idea that is. I wouldn't have done it. Trimming your existing studs by 1/4 inch is likely a better option than stacking. Or return the works and get 2 inch ones.
I thought of that but there is a risk of damaging the threads if I cut the studs. Im not sure if they make a 2" or if they do I sure could not find it. I was planning on stacking the 1/4" spacer on back side of 1.5" spacer. this will give me a full lug nut threaded and still clear to install wheel.
I wouldn't honestly hesitate to cut them, stack a few washers on the lug, enough so when you tighten a lug nut over the washers it leaves the desired amount to be cut off. Grab a hack saw, and cut em clean. Spin the nut off, and run a quick file around the outside of the stud. The lug will clean up the threads on its way off. An added security for thread protection, is to use body shims instead of washers. Then once the stud is cut, loosen the nut, remove the shims, and tighten the nut back down. Then clean up the edge with a file, and run the nut off after its cleaned up. It'd bullet proof that way, but tedious.
No matter what, you need to be positive here that your spacers are not made of cast aluminum. I wouldn't trust any made in china spacers.
Mine are holding up fine. inlandwheel and tire is where I had mine made. around $300 I think. Not sure.
Thread is here with pics
