Backspacing Question
How wide are they? check my gallery..ive got two of my trucks with the same offset wheels you are looking for....9"wide with -12 offset or 4.5" of backspacing...you are going to have rubbage with a 34.8" tire...stick with a 33 as my recommendation...if you dont care to trim , then hop toit. You will need a dremel and need to cut a little sheet metal on the rear section of your front fender well. there are some trimming threads you should search for.
The Hostage is only offered in a 4.5bs or 5.25bs for my bolt pattern, the 5.25bs has an offset of 6mm, which isn't a lot, but it's better than -12 lol
Their only 285s so 11.2" wide which helps quite a bit on the not rubbing part. i had 295/70R17s (33x11.6) on stock everything with no rubbing...
