Going from 18's to 17's OK on an 08?
Finally found a set of rims and tires that i think will look good on my truck but the rims are 17x9 (stock is 18").
Before i buy, I wanted to post the specs to make sure I'll have no rubbing issues or any other issues.
Specs:
2008 4x4 Scab Lariat
Wheels - 17x9 Gear Alloy 713 Double pump 6.18 BS (+30 offset)
Tires - Nitto Terra Grapplers 305/70/17 (33.8 x 12)
Lift - (will be leveling at same time - Not sure if 2" or 2.5" yet or what brand)
I would have rather stayed with stock 18's but my wheel choice only came in 17x9 or 20x9 and not crazy about the look of 20's unless it has 35's or bigger. The 17" package is also $500 cheaper.
Any rubbing issues with this setup?
Any problems with brake rotor clearance going down to a 17 inch rim?
Any recommendations on a leveling kit brand? Which ones come with a rear block if I need one?
No other offset with the rims and I think I may be disapointed that the tires wont stick out as far as I was hoping for but I guess I can add a spacer if need be.
Specs:
Sounds good. I was worried about brake rotor clearance cause i was told they use larger rotors when going to the 18" wheels.
I would say 2" if you don't want it to bulldog any. But you can park on level ground and measure to see exactly how much higher your back end is than your front. I would measure from the ground to the bottom of the front door and back door and see what the difference is
This is my old '04 with a 2 1/2 inch leveling kit with 295x70x17 Toyo MT's on 17x8 wheels with 5.5 inches of backspace. Your wheel's will stick out 1/2 inch more then these. The '04 and '05 truck's needed a 2 1/2 inch kit because the rear sat higher. Your '08 should be fine with a 2 inch.
I'd level the front first then see how the truck look's and rides. You can alway's lift the rear later if you need to.
I do want a slight rake though.
Some of the kits ive been seeing on ebay have 2.5 front and 1.5 rear like this one.
http://www.ebay.com/itm/140668592909...84.m1423.l2649
and some have 3.5 front & 1.5 rear like this one
http://www.ebay.com/itm/350482910554...84.m1423.l2649
and some have 2" front & 1.5" rear like this one.
http://www.ebay.com/itm/250863035125...84.m1423.l2649
Im sure there is other sizes as well.
I guess best option is to measure and hope ... lol
I've read about problems with higher front lifts though with the CV boots which concearns me.
